Further....perhaps final.....thoughts on the L800
TroyD
TroyD Posts: 13,124
edited March 2022 in 2 Channel Audio
Ok, I typed this darn thing once and lost it so I'm a little PEEVED.
So, anyway, I've had these playing pretty much non stop for the last 2.5 weeks....what that equates to in hours I dunno and frankly don't care. I haven't heard any appreciable difference in sound for the last week or so.....so here goes.
So, bottom line. These are the best speakers Polk has ever made. Hands down. Bar none. Better than the modded SDA's. Better than the LSiM's.....you name it. Top to bottom coherence that Polk has previously never been capable of. Uncolored. Bass? I gotta say, I'd be hard pressed to think of a speaker that has had this level of bass output, detail and musicality. Really. I can't think of one......and not at the expense of overpowering the midrange. Phenomenal achievement. The SDA imaging that we know and love comes with an extra helping of 3 dimensionality and detail that previous SDA's.....modded or not...have not been capable of.
Now, F1Nut and folks who are enamored of the previous generation of SDA's....they are different animals. Not better or worse per se but different. I know F1Nut and his listening preferences well enough to know that these will not be his particular cup of tea with moldy cheese (and you can't put a plant in front of them)....so, comparing these to the previous SDA's is not an apples/apples comparison and isn't worth doing.
Listen to Sara K's Waterfalls, The Eagles When Hell Freezes Over and Santana's Abraxas and you will hear everything that these are capable of and you will be screaming SHUT UP AND TAKE MY MONEY!!!
However.....there are some caveats. Andrew Robinson touched on some of them and while I think he was FOS on most of it...some of it, he's got a valid point.
These speakers are very unforgiving of:
1. Bad recordings. Great music / low-fi recordings and streaming...BLECH. Bruce Springsteen Born to Run. Boston self titled. Pretty much ANY Columbia classical recording (Mahler's 2nd by Bruno Walter comes to mind. UNLISTENABLE. I have a lot of music that I like that isn't recorded well....The Pretenders come to mind also....that are not pleasant to listen to through the L800's
2. Bad gear. Or the right gear. I had a longer preamp umbilical cord for practical reasons...so I had the Adcom/Sunfire hooked up for a minute. A MINUTE. That combination sounded like pickled a$$. Zero soundstage depth. Lifeless and uninspired. So, yes, the gear makes a difference
3. Sound levels. These are TERRIBLE at low volume. Now, in my situation, this really isn't a big deal. If TLW demands quiet, I can go listen to the Carver Amazings. No big deal....and the living room is big enough so the volume is usually sufficient to not be a big deal .....but at low volumes, everything COLLAPSES.
Now, this may sound like a litany of complaints.....but at this level of fidelity, and I would argue that the L800's compete well at the 10K-15K level, I think loudspeakers are, by design, idiosyncratic. So, some of this really is, IMO, the nature of the beast.
So, will the L800's be a long term resident at the Rancho de No Concerno? Probably. They aren't my "end all/be all" speaker.....that will probably be a planar design. If I could step into a Magnepan 20-series, that's where I see my destination being...but until that time, I think they will do!
    Clipdat Posts: 13,100
    Who is Andrew Robinson?
    Also who is F1Nut?
    mhardy6647 Posts: 35,354
    Who am I? Why am I here?
    ahem.
    @TroyD Potent review, there.
    What are you using for amplification with them?
    (I should probably know... but I don't)
  • TroyD
    TroyD Posts: 13,124
    Doc,
    I am using a Musical Fidelity Tri Vista integrated
    msg Posts: 10,528
    Troy, do you use an SPL meter for general reference? What would you consider lower listening levels?
    Is it the sound in general, or just the lows you find lacking at lower volume?
    My typical listening level is mid to upper 70s with Peaks into the upper 80s.
    Thinking about seeing if I can integrate a sub now after having had them running solo for a few months. Just to see how that goes. It would be a MartinLogan Depth-i.
    nooshinjohn Posts: 26,058
    I don’t have anything bad to say about low volume performance. In my space they do quite well.
    VR3 Posts: 29,625
    You have a way with words Troy!
    Pickled **** should be a staple comparison in any review!
    Glad you are digging the l800!
  • TroyD
    TroyD Posts: 13,124
    No, I don’t use an SPL.....and really, this is not a knock as I think most speakers have that threshold where things start to collapse. I just think that threshold is a little higher for the L800’s
    My only real complaint is the total unwillingness to lend a hand to lesser recordings.....
    And reading over my thoughts, I think perhaps my opinions of midrange reticence is probably because the Bozaks were downright lush in the mids...
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,919
    Sara K's Waterfalls >>> Sweet music; never listened to her previously.
    Harry / Marietta GA
  • TroyD
    TroyD Posts: 13,124
    All of her stuff is good...
    msg Posts: 10,528
    I'm holding out for final-final thoughts.
  • TroyD
    TroyD Posts: 13,124
    L800's - Final Answer
    So, pretty much my thoughts above are unchanged.
    To repeat: Best speaker Polk Audio has ever produced. Hands down. I think if you are looking for a dynamic speaker under 20K.....I think the L800 deserves to be on your short list to audition with the the above mentioned caveats.
    Is it going to be a long term solution for me.....the jury is still out on that one.
    At the end of the day, I'm a planar/ribbon guy. Quads/Carver/Magnepan have been my primary listening speakers for the better part of a couple decades. Eventually, the L800's will more than likely move aside for a pair of big Magnepans. The 1.6's are great but they don't move QUITE enough air for the living room. 3.7's would be ideal IMO (20.7 if I win the lottery...) so that's probably the next stop.
    Toolfan66 Posts: 18,281
    The modules L900's I believe that you can put in the top are for surround sound only correct? Same thing as having a height speaker right? I am sure I just could go to the top of the page where it says products and find my answer but I am on lunch, so screw that.. LOL!!
  • rooftop59
    rooftop59 Posts: 8,120
    Toolfan66 wrote: »
    Yes, Dolby atmos height modules. In ceiling speakers are ideal, but these are probably a decent substitute
    Game Room 5.1.4:
    Bedroom 2.1
  • Emlyn
    Emlyn Posts: 4,864
    edited March 2022
    The L900s work pretty well as front height effects speakers for rooms where the sound can bounce off the ceiling and impact the listening area. They're not as ideal as height speakers that would be in ceiling. Those are more enveloping. The L900s to me are for those who don't want to spend the money to run wires and cut into the ceiling to get in ceiling speakers or for those where in ceiling speakers are not an option.
    I now have access to three Atmos setups and none of them have in-ceiling speakers. Two have Atmos speakers built into the tops of the front main speakers and one has separate modules. They all work well but the external modules work best among the three systems.
    txcoastal1 Posts: 13,519
    rooftop59 wrote: »
    Toolfan66 wrote: »
    I have had good luck with my 900's installed in my L600, but I also a gambrel ceiling directly above them.
  • TroyD
    TroyD Posts: 13,124
    I’d be lying if I said I knew anything about what atmos is or does.....
    VR3 Posts: 29,625
    It makes you feel like you're up in the atmosphere
    VR3 wrote: »
    You mean kind of like the contact high you get from hanging out with Bud?
    VR3 Posts: 29,625
    VR3 wrote: »
    Totally man......
    edited March 2022
    Dude...
    what was this thread about?
    Got any Doritos?
    Or is it Doritoes?
    whoa...
  • TroyD
    TroyD Posts: 13,124
    Look at the birds up in the trees....
    pitdogg2 Posts: 27,533
    IN THE TREE'S.........NO WAY MAN!
    heiney9 Posts: 25,573
    So to get a little bit back on track. I am seriously considering the L800's in my long term plan. I didn't follow the initial posts when they were first released.
    Did we ever get the single ended/non-common ground issue sorted out. I did read that you can run a non-common ground amp but the SDA properties are diminished. That's a huge problem for me and the Pass gear I want to run with them.
    Plus they are really deep speakers and I'm not sure I have the front to back real estate w/o it looking a bit odd. It's my understanding they don't have to be as far out from the wall as my SDA 1'C's.
  • JayCee
    JayCee Posts: 1,509
    edited March 2022
    heiney9 wrote: »
    Not compatible and I'm in the same boat. My PS Audio BHK stack/DirectStream DAC combo is fully balanced from top to bottom. Big disappointment not being able to run my TOTL gear, however, I knew this when I purchased the 800's. Right now, the 800's are in my living room running HT duty w/the modded Parasound HCA-1500A and BDP-105 combo. Best speakers I've had in that room but I know I truly haven't heard all they are capable of. I have other end game speakers (Genesis Gen II's) in play for later down the road but I'm not sorry I picked the 800's up.
    One thing I've considered, and not done other than just taking the time, is hitting up Scott Orth and seeing if there is a solution he might have insight into like the the original Dreadnaught. Not asking Polk to build it, I think the DIY crowd here could w/the right help, but wouldn't hesitate to purchase one if Polk offered it.
    Perhaps, now is the time?
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    I run my L800 on mono amps with zero difficulty. It is differential amps that are a problem with the new SDA...
