Then on AVR-590
Captorofsin
in Speakers
Hello everyone new to the forum. I currently have a den on avr-590 5.1 receiver. I'm entertaining the idea of running
Polk signature series all the way around. Floor standing speakers up front, a center channel (of course) and bookshelf speakers in back.
Our signature series speakers a good match with the AVR-590.
If your question is, will your receiver work with the Polk Sig. series, then yes, it will work. Will you get the most sound quality wise out of the speakers with that receiver, then the answer is probably not.HT SYSTEM-
lsi 9's -
Hello. Thanks for answering my question. I was thinking that because Polk and Denon (along with Marantz and Boston acoustics) are the same company, that they would "mesh" good together.
O know both are higher end names.
I do like the Polk sigs. I was thinking ES50, ES55, or ES60 for fronts and for surround I was thinking ES10, ES15, or ES20.
For center either ES30 or ES35
I have also been eyeballing these from amazon
https://www.amazon.com/Polk-Signature-Elite-Speaker-Bundle/dp/B09L38W97Z/ref=sr_1_29?crid=33AIW7CDUTNZ0&keywords=Polk+Audio+Signature+Elite+2x+ES60+Floorstanding+Home+Theater+System,+Black&qid=1646692875&sprefix=polk+audio+signature+elite+2x+es60+floorstanding+home+theater+system,+black,aps,177&sr=8-29
https://www.amazon.com/Signature-Elite-Theater-System-Bundle/dp/B09L34GJ2H/ref=sr_1_17_sspa?crid=2B5REUU6DUSS3&keywords=Polk+Audio+Signature+Home+Theater+System&qid=1647027360&sprefix=polk+audio+signature+home+theater+system,aps,119&sr=8-17-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExQ0xNN0NXMlFNREgxJmVuY3J5cHRlZElkPUEwNzAwNjgxRURDV0dVOVFQV0FZJmVuY3J5cHRlZEFkSWQ9QTA0MTA0OTdBSFJSMjFOTFVXNkcmd2lkZ2V0TmFtZT1zcF9hdGZfbmV4dCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Do those Polk Sig 20s do a good job in combo with your SW?
