Speaker Identification
Says model 10 but which one? Only have these 2 pictures to go by...
    F1nut Posts: 52,011
    The really early one.
  • joebass3
    joebass3 Posts: 311
    I thought so because no terminal cup. What drivers are used in those?
    mhardy6647 Posts: 35,244
    Agree with @F1nut -- not the earliest possible, though, as the earliest ones had barrier terminal strips rather than double banana jacks. :|
    xschop Posts: 5,417
    If we're being pontificators, I'd reckon 10A's with an twist of nuanced "wing-it" from the factory x-over dept.
    F1nut Posts: 52,011
    joebass3 wrote: »
    You'd have remove them to know for sure.
  • joebass3
    joebass3 Posts: 311
    Are these worth making an offer on? If so how much? Stands are included. Cosmetically probably 6-7 out of 10.
    F1nut Posts: 52,011
    edited February 2022
    Is that a Polk passive radiator?
    Looks like a very early Model 10 with the uncoated paper PR to me (and FWIW). :)
    Like this one (half of a pair)...
    11208619575_674f036d9b_c.jpgP1020559 by Mark Hardy, on Flickr
    That little red racing stripe ;) surrounding the mass load in the center of the PR seems to be characteristic of 'em. :#
    EDIT: Also note the sinful (ahem... unholey) Peerless tweeter -- just like the ones here!
    @joebass3 the one you posted the photo of looks to be in phenomenal condition for a ca. 1975 (or maybe even a bit older) loudspeaker. I think my only concern about them would be frozen "midbass" drivers due to magnet shift.
  • joebass3
    joebass3 Posts: 311
    I only took out one of the MW's to take a look. Took a pic of it hoping to identify it. Not sure if it's a passive radiator or active woofer. The speakers appear to be unmolested.
    F1nut Posts: 52,011
    Thanks Mark, so definitely a Polk passive.
    pitdogg2 Posts: 27,344
    Early silver basket should be mw6500 drivers. I remember an advertisement one time which Polk had a brand new driver coming on to the market. It was the mw6600. Up until that time I believe they were all mw6500. After the mw6600 came out they then started going to the 01, 02, 03 etc numbering system.
    I could be wrong.
