Resealing inside joints Polk SDA 2B
rhythm
Air leak test results aren't very good so I'm going to finally apply a sealer around the inside joints of my speakers. All the gaskets seem fine. I just wanted to ask a couple of questions. Is the product pictured what I want to use? There are so many variations but I think I bought the right stuff. Also, about how long would you suggest that I let everything sit and cure before re-assembling the speakers?
Thank you!
Greg
Thank you!
Greg
Yes.
Let it sit over night. Don't be shy get a good amount on the surfaces and smooth out on both sides of the walls.
