Polk Monitor 10 how to remove woofer?
I want to remove a driver from my Polk Monitor 10s to see which driver version it is. Sorry for the dumb question, but is it "glued" in and do I need to redo it after removal or how do I remove and / or replace it?
    F1nut Posts: 52,061
    It's not actually glued in. At the time Polk used a product called Mortite instead of real gaskets. Unfortunately, the Mortite tends to become a bonding agent. You will have to pry the driver out.
    After removal scrape all that crap off and replace with speaker gasket material such as sold at Parts Express.
  • ken brydson
    ken brydson Posts: 9,043
    Not glued in, just remove the screws. Might need a bit of gentle prying as it may seem stuck after 40 years. Be careful not to damage the gaskets as you'll need to reuse them.
    F1nut Posts: 52,061
    I suggest you have someone ready to catch the driver as prying it out will make it pop out.
  • He has the light grey foam gasket tape like mine came with. You can see where the tape sticks out where it overlaps.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,496
    edited February 2022
    Lay them flat on their backs. Mask tape the front face where your thin screwdriver will be prying as to not chip/damage the black laminate baffle material.
    VR3 Posts: 29,590
    [remove terminal cup in back. Remove pr using pressure from back. Remove midbass from within the pr hole
    F1nut Posts: 52,061
    VR3 wrote: »
    That's another good way, but more work. I use two stiff putty knives, one on each side of the driver. The wide blade is much less likely than a screwdriver to damage the bezel.
  • jdjohn
    jdjohn Posts: 3,399
    Maybe with the rear terminal cup removed, the model numbers of the drivers can be seen from inside, and won't have to actually be taken out.
