Replacement driver for old Polk RT-7 bookshelf speaker
EditorJack
in Speakers
I have a wonderful old set of Polk RT-7 speakers, but one of the woofer cones is getting a little raspy. What modern speaker would you recommend to replace it? Thanks for your help.
Answers
Try rotating the driver- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Gravity, eh? I'll try that. Thanks for the suggestion!
If that doesn't work, do you have a replacement you can recommend?
Best bet is eBay, but gravity should do the trick- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
