AV123 EL525 Monitors in Cherry veneer
AV123 EL525 Monitors (small bookshelf) speaker pair. $225 - you pay shipping or Pickup in Rockford IL
Crossovers have been upgraded as the picture shows and wiring was also upgraded. Very nice sound.
Badges are no longer attached and if I find them will be included but not attached.
Some small dings on top and on the back as shown in the pictures. This is real cherry veneer and not a vinyl wrap.
Technical Specifications
ELT525 Monitor
System Description: 2 Way
Woofer: 5.25” treated paper cone
Tweeter: 1” fabric dome with oversized surround
Enclosure Type: Vented, Rear Firing
Frequency Response (+/-3dB): 60Hz- 20KHz
Nominal Impedance: 8 Ohms
Sensitivity: 83dB @ 1w/1m
Crossover: 2200Hz, 2nd Order Acoustic
Raw Weight: 24 lbs pair / 10.8 kg pair
Dimensions: 6.12” W x 11.25” H x 9.81” D / 155mm W x 287mm H x 250mm D
Mounting: 1/4”-20 threaded insert built into the back and bottom. For wall mounting, we
recommend Peerless item# PM732
Video Shielded: Yes
Aaron
Enabler Extraordinaire
