Brackets for RM6000
stott281
We just finished remodeling our great room and I thought ahead and ran monster cable for the left, right and surrounds before the finshed off the walls. Where can I find good brackets for the satellites? Do they sell them here on Polk's website? Any help would be appreciated.
Post edited by stott281 on
yes, you can usually purchase brackets from club polk, but according to the website:
"OmniMount Brackets are heavily backordered and unavailable from polkaudio.com for the moment. We're working hard to get them back up here for you."
here's the link if you would like to check it out anyways:
http://clubpolk.tranguard.com/list_categories.asp?tgs=20065:21956452&cart_id=&id=15
...good luck!
joe
i ordered ominmount brackets for my rt25i's for rear center's and they worked great. if polk is backordered, you can order these many other places on the web, just do a search....
Thanks guys! That was quick!
