Larry’s Rings
I recently found a set of Larry’s Rings for my SDA-2BTL project. The set was made for SDA-2’s, so I’ve got an extra pair of 6.5” rings. I’d like to use them on my Monitor 7’s, so my question is does anybody have any extra 10” passive rings lying around? I’m sure it’s a longshot, but you never know…
  • Gardenstater
    Gardenstater Posts: 4,804
    Another option could be @xschop semi-rings in your 7's, for the MW anyway. I believe the benefit I got is huge because of the very wide baffle on the Monitor 7. Can't beat a couple chunks of 1/4" thick and 1/2" wide steel epoxied or construction adhesive'd in for rigidity. You won't believe the slam you will get! I don't know when he will be able to find time to do another run.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,417
    I made a few extra rings a couple weeks ago if you're interested.
    For the PRs you can just use hurricane nuts. The lower semi-ring will stiffen the baffle in its' weak spot between MW and PR.
