2ch amp driving 4 speakers
Steve@3dai
Steve@3dai Posts: 983
edited June 2004 in Car Audio & Electronics
Okay, my Zapco does 50x2 @ 4ohm or 100x2 @ 2ohm. If I hook up 4 speakers in serial to it, (all 4 ohm, which makes the load 2ohm), do you think it would sound alright? I really want some rear fill because I do have people riding in the back seat, but don't really want to invest into another amp.
I would be running MMC650s in the front and db525s in the rear.
Gracias.
LSi 9/C/FX
Arcam AVR-200
Post edited by Steve@3dai on
  • AustinKP
    AustinKP Posts: 861
    edited June 2004
    You can do it, but you lose the ability to fade from right to left. You'd still have balance from front to back though. It just reduces your fine tuning and tweaking ability. Wouldn't hurt anything though. Good way to get the full power from your amp.
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2004
    Serial? That would be paralell. Serial would be series which would be an 4 ohm load.
    Another downside would be that your rear speakers will be the same volume as the front which will skew your soundstage drastically. And also since youll be having the same frequencies hitting you from different distances, the detail will smear a bit.
    It will work fine for most people but if youre super picky about your sound quality then you probably would be a lot happier with a 4 channel amp that you can fade or bett yet, doing without rear speakers at all.
  • Steve@3dai
    edited June 2004
    Ah, right, parallel, forgot. That's what I meant ;)
    Hmm, well being that I have a loud exhaust, not the best quiet tires (chose sticky over quiet) I'm not REAL concerned about the super details.
    I've got my home system for that :)
    LSi 9/C/FX
    Arcam AVR-200
  • exalted512
    exalted512 Posts: 10,735
    edited June 2004
    why not just run them off the HU?
    -Cody
  • Steve@3dai
    edited June 2004
    My head unit doesn't have an internal amp.
    I hooked up the rear db525s to one of the Zapcos yesterday, did the full wire-through-the-door and everything (12g wire). So I am sans sub at the moment, but it still sounds nice and has some good bass. I'll see what the MMC650s do to the car (they'll be replacing ex365 (components)).
    LSi 9/C/FX
    Arcam AVR-200
  • exalted512
    edited June 2004
    ahh ok, what kind of head unit do you have?
    i wished mine didnt have an interal amp...
    -Cody
  • MacLeod
    edited June 2004
    Get ya an Alpine. Most models have a the option of turning the internal amp off.
  • exalted512
    edited June 2004
    i can do it with my pioneer to...they just have another name for it
    FADE;)
    i dont use the internal amp on mine because all of my speakers are amped
    i wish it didnt have one because it mightve been cheaper:)
    -Cody
  • AustinKP
    AustinKP Posts: 861
    edited June 2004
    -Cody
    Yeah, probably not. The Alpine 7995 was like $100 more than the next step down. Only difference I could tell was a different color and no internal amp...
    Alpine 9815
  • Steve@3dai
    edited June 2004
    I have an Empeg/RioCar.
    I wanted 50Gigs of MP3s instead of internal amps ;)
    LSi 9/C/FX
    Arcam AVR-200
