Can you help me identify these?
These are available on my local Craigslist. The owner is asking $150 for the pair. What are they and is this a good deal? Thanks!
Best Answers
  • stangman67
    stangman67 Posts: 2,328
    Answer ✓
    They say it all. Rt2000i’s!
  • stangman67
    Answer ✓
    As far as if it is a good deal or not, if they are in great shape it should be a decent deal. Biggest thing is to ensure the installed amps work
Answers
    pitdogg2 Posts: 27,210
    Alex, What is Polk SRT for 100 please.
    Maybe RT
    Either way ask about any amp problems or past work.
    F1nut Posts: 51,930
    The SRT towers looked different. RT something.
    edited January 2022
    I went off the base, it looked big
    My second was RT 3000/5000. Never seen them in the wild personally.
  • stangman67
    RT1000P I believe
  • Thanks for weighing in without much info! He sent a pic of the back of one tower. There’s an RT at the beginnings of the serial number. Does this help?
    BTW this would be for fronts for home theater in a man cave that’s just in the dream stage so far.
    Toolfan66 Posts: 18,149
    I would pass myself, working or not, those amps are a deal breaker for me…
  • jbreezy5
    jbreezy5 Posts: 1,141
    Also would pass on these. IMO, other Polks are likely available that sound better for similar cash, among other brands.
  • This has all been very helpful! I had no idea Polk made any speaker with a built in amp. I’ve had good luck with with older speakers but not with older subwoofers. The amps fail! I appreciate the good advice.
