Back box for vanishing series?
Currently renovating my living room and chose to go inwall, using the following speakers.
255c-rt for center
265-rt for right and left
65-rt for rears
Rc60i for ceiling
Wondering if they will require back boxes and if they do does anyone know the proper box size to be used?
255c-rt for center
65-rt for rears
Rc60i for ceiling
Answers
I doubt any of them require back boxes as some of them would be tough to install depending on the depth of the wall/ceiling let alone stud placement, and where you would want to mount them..
I installed atmos speakers in the ceiling in the basement, cut holes, ran wire, and installed, they sound great..
I should note that the back boxes would probably give you better sound quality, especially in the front stage, and maybe add some polyfill behind them... -
Here, this may just answer your question better.
https://forum.polkaudio.com/discussion/195590/in-wall-speaker-back-box-design#latest -
Thank you very much Toolfan66, much appreciated for the help/advice!
