Polk SDA1 (1st Gen) w Adcom GFA555 Common Ground
le91163
le91163 Posts: 3
edited December 2021 in Vintage Speakers
Hello, I have gone old school and bought a 40 year old pair of polk SDA1A W sL1000 Tweeters and from what I can tell these are first generation of this model type with silver tweeters, if that makes a difference.
I also got the interconnect cable as well.
I also have an Adcom GFA 555 that I bought in 1988 that I think would work well with these speakers.
The back of the polk says I must use an amp with a "common ground. "
Question I have is this.. does my Adcom have a common ground? Can anyone in this group verify or steer me towards finding and answer?
Thanks in advance.
    pitdogg2 Posts: 27,423
    The Adcom you have IIRC is common ground. From my understanding the 4 number series like 5500, 5800 for example are not common ground.
    Here is a way to double check. Remember Amp off, no cables hooked up.
    Schurkey wrote: »
    What ohm reading do you get when testing left black speaker post to right black speaker post?
    I don't know of a better test than a simple ohmmeter connected across the black posts. Less than one ohm resistance, you're set. Of course, this will require the amp to be in stereo mode, bridged/balanced amps are not SDA-compatible without an isolation transformer.
    I have heard of manufacturers who don't friggin' know whether their product is common-ground or not, and give bad advice to SDA owners. Adcom, for example has told at least two folks on this forum that a certain product is common-ground when it was not.
  • boston1450
    boston1450 Posts: 7,758
    Yes. 555 I used on my SDA2b & with a good preamp it will sound very good. IIRC the 555 can be modified/upgraded also. Being it's age. Nice amplifier for SDA'S
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Schurkey
    Schurkey Posts: 2,122
    The 555 should be common ground. Others have used them successfully.
    Be sure you check DC offset before you connect them to your speakers. The offset is not adjustable, it's controlled by a pair of MATCHED transistors; and they get un-matched or outright fail over time.
    That amp is old enough that you'd do well to have it properly serviced. It's a fine amp, has lots of potential...but it's old and may need some lovin'.
    Some folks are weirded-out by the lack of protection circuitry; but I don't think that's a particular problem provided the amp is in otherwise good condition. Again...that amp is old.
  • TennMan
    TennMan Posts: 1,266
    The GFA-555 is definitely common ground. I've been running one for several years with my SDA TL-2Bs without problems. I'm very happy with it. I think it would have plenty of power and be a good match for the SDA 1As.
    There are several mods that can be made to the 555. Upgrades have been made to my 555 that are similar to the LX Mod made by Musical Concepts to the GFA-555. A speaker protection board was added at the same time that shuts the power off to the speakers if a problem is detected. The board also delays sending power to the speakers for a few seconds when the amp is first turned on. That eliminates the "pop" or "thump" that sometimes can be heard in the speakers when you turn a 555 on. You can see the board mounted to the right side of the cabinet in the photo below.
  • Schurkey
    I just love topless photos.
  • vader540is
    vader540is Posts: 191
    edited January 2022
    TennMan wrote: »
    Beautiful. I might do this mod with my GFA555.
    I also recently acquired a NAD 2200 and I'll be comparing both of those amplifiers back to back.
  • Have had the 555, never an NAD. I would really be interested in the A / B of those two amp.
  • woodsman wrote: »
    In a few weeks I'll be going over a buddies house and we will A/B the 555 and the NAD 2200.
    We will be using the Philharmonic BMR
