Can the S15 really be wall mounted?
Folks - I'm a little concerned about finding a thread which shows the S15 have a design flaw with wall mounting - https://forum.polkaudio.com/discussion/177041/keep-these-s15-speaker-mounts
It also turns out my S15 also have cracks since I mounted them in a different apartment before and now re-mounting in my new apartment. Should I just avoid wall mounting and buy low profile brackets - can somebody recommend something that's cost effective for 4 speakers?
Once again,The Internet is full of wall mounts for speakers. Here's one, https://www.rockvilleaudio.com/rhsb8-for-polk-audio-s15/Political Correctness'.........defined
President of Club Polk -
out of stock; any other recommendations? Thank you
Is there something that prevents you from searching the Internet for yourself!?!
This is the last help you'll ever get from me.
https://www.amazon.com/dp/B079ZSS7HP/ref=cm_sw_r_cp_apa_glc_i_69G4CVVQDZ8Q4EMSXAVVPolitical Correctness'.........defined
I am also looking to wall mount a pair of S15 speakers. Unfortunately the Rockville RHSB8 that have been posted are not available in my region and, while equivalents do exist, can't be angled down far enough for my use case (looking to mount the S15 near the ceiling for height effect. I am wondering if an option would be a this mount:
https://www.adamhall.com/shop/us-en/installation-equipment/installation-loudspeakers/accessories-for-installation-loudspeakers/5753/suwmb-10-w
Which would require me to screw the mount directly into the speaker enclosure, either at the side or at the top. Is that safe to do or do I risk damaging the speaker (the audio I mean, I'm aware it would cause cosmetic damage). -
Mounting into the cabinet won't effect the sound, it should be fine.
