Repair HCA-1500 or buy another amp?
I bought this Parasound(it's not the A version) used about 3 years ago. It has performed well up until the other day. Out of nowhere the right channel is almost non existent. At first I suspected the preamp as it had problems in the past. After many cable swaps, etc I have narrowed the culprit down to be the power amp. So I'm wondering do I pay to ship it back to Parasound for a refresh, take it locally for most likely a little less $$ but also a little less amp(if you know what I mean)....or sell it to someone for repair and buy another used amp. What would you do and why?
Yep, my name really is Bob.
    VR3 Posts: 29,609
    Absolutely send it to Parasound! They will even ship it back in new factory packaging, atleast they did for me! Well worth the extra freight.
    Great amp!
  • skrol
    skrol Posts: 3,473
    I didn't know they would refurb an old amp. They have been great about helping me with schematics and info for my amps.
    The problem with your amp may be a bad solder joint. I got one of my Parasound amps for a steal that sounds like it acted the same as yours, though it could be something else, because of a bad solder joint on one of the large bias resistors.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    I'd at least get an estimate on the repair. That's a nice amp to just toss. Probably one of the best bang for your buck amps out there.
  • muncybob
    muncybob Posts: 3,276
    A local shop is familiar with the amp. Other than finding/fixing the problem, what else should I ask them to do while they have it? I'm sure they will have suggestions but I don't want to say OK to things that maybe really aren't needed.
    In the meantime, I have put the HCA1000 in its place with the 2 channel rig. This is my 1st experience with noticing a definitive difference in sound between amps.
    VR3 Posts: 29,609
    At its age I would seriously considering a recap main filter caps and double check bias while on the bench
  • skrol
    skrol Posts: 3,473
    edited December 2021
    +1 on the re-cap. I have an HCA-800ii from the same era of Parasound that I refurb'd. Thirty percent of the electrolytic caps were out of spec or bad. I also refurbished the Parasound pre-amp (C/PT-600) at the time and found the same failure rate. Upgrading to Nichicon FG and Muse in the combo made a huge difference in the noise floor and SQ.
    I also have an HCA-1000A that I refurb'd. By contrast, they used better quality caps and just a couple were out of spec but I upgraded to better quality anyway. The biggest upgrade was the PS caps that, according to Mr. Curl, was a compromise at the time due to space constraints of the thinner cabinet and what was available at the time. I was able to go higher capacitance and higher voltage rating (Nippon Chermi-Con). The originals (Elna) were spec'd right at the rail voltage.
    Stan
    Main 2ch:
    HT:
    Other stuff:
