Polk DSW PRO 600 grumbling and shutting off after few seconds
I got a used DSW PRO 600 subwoofer and when I first turn on, it works and produces bass but after 10 - 20 seconds, it growls like bottoming out and no sound.
It happens quick if volume is high.
Is it the amp or something else?
    treitz3 Posts: 20,141
    Hello, Mystery. That *sounds* like a bad board from what you are describing. (The plate amp). I am pretty sure there are not any user serviceable parts on the board, so you would need to contact Polk and inquire about getting a new board.
    When you push the woofer in and out (gently), does it move freely, or is there any hesitation or grinding feel to it?
    F1nut Posts: 52,037
    Yep, the plate amp has bit the dust.
  • Mystery
    Mystery Posts: 2,546
    treitz3 wrote: »
    Hi Tom, yes the woofer moves freely although it's not as free as regular speaker.
    No grinding or hesitation but stiffer than regular speaker woofer that's probably normal with subwoofer.
    When it works for few seconds, it does sound fine.
    Power light stays on even after it stops producing sound.
    If I turn it off and turn it back on, it works again for few seconds.
    Maybe a cap or two are bad.
  • Mystery
    Oh well.
    I got it untested as a package deal with Klipsch RB-81 speakers so didn't pay much.
    Maybe I can salvage it for few bucks. It's pretty big and heavy sub so someone probably can use it.
    Toolfan66 Posts: 18,212
    Mystery wrote: »
    Oh well.
    I would take a shot at polk having a board for it first, I know it is probably a long shot at this point with the age these are now, but polk did replace the board in my 500 and 600 when when I did own them a few years ago. but you might just get lucky, and you would have a sub that would/could last you 5+ years..
