I am planning to buy a dedicated amp for my RtiA9's (fronts).
jsaldanha
I am planning to buy a dedicated amp for my RtiA9's (fronts). Please recommend if Emotiva XPA (2 channel) would be sufficient (300 W pc @ 8 ohms) or would I require a more expensive Emotiva XPR (550 W pc @ 8 ohms). Please recommend, also if members have an Emotiva XPA used to drive Polk Rti A9's. does the amp drive the speakers well enough or seem short of power.
I am currently driving my fronts with Yamaha Aventage 3070 (Fronts bi-amped and 7 other surround channels), the front channels seem grossly underpowered.
Answers
I think Parasound would be a better match for RTi series vs Emotiva.
Don't do the fake bi-amping thing. -
The problem with pseudo bi-amping with receivers is that the more channels you use the less power they all have. Some get down to 40-50wpc or less on a good day.
Everything the other guys said is the correct advice.
