Pro-Ject Tube Box S2 Phono Preamplifier?
Thinking about the above to replace my Parasound Zphono with USB, would it be an improvement? I'm wanting to stay in the $400-$500 range. Is there any other unit I should look at, also what tubes would be recommended with it?
If not much of an improvement in the above, I'm thinking about upgrading my CD player with a refurb Marantz CD6006. Opinions?
  • Milito
    Milito Posts: 2,003
    Also anyone tried the Rega FONO MC Phono Stage?
  • dromunds
    dromunds Posts: 10,129
    The z-phono is good bang for the buck. I doubt that Pro-Ject would be a move up. What specifically is it that you are looking to improve? Adjustability to your cartridge is a plus, what cart are you using?
  • Milito
    Milito Posts: 2,003
    I'm using a Ortofon 2m blue cartridge on a Fluance RT85. Just wondering if a tube phono amp would give better sound?
  • engie490
    engie490 Posts: 442
    Keep in mind that the Tube Box is actually a hybrid and uses FETs and tubes. I think the difference between it and the Parasound stage will be pretty subtle.
    If you're looking for a full tube phono stage, try the Hagerman Cornet3. It's MM only, which is what you're using anyway.
    Infinity RS-1Bs / Bryston 7B STs / Sonic Frontiers Power 2 / Jeff Rowland Consonance / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • Milito
    Milito Posts: 2,003
    Clipdat wrote: »
    So do you think it would be much of an improvement over what I have. I probably won't be using XLR cables for a good while if ever? I will be using an Ortofon 2m blue with it.
    Clipdat Posts: 13,095
    I certainly believe you would hear an audible improvement, yes.
  • Milito
    Milito Posts: 2,003
    Thanks.
  • xsmi
    xsmi Posts: 1,801
    I actually think you will. That Pro-Ject phono preamp is a dual mono design. I don't think you can go wrong with either the XRM or the Tube Phonobox.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • dromunds
    I think I’d save up for a marked improvement
  • Milito
    Milito Posts: 2,003
    Yea, I think I'll wait to see how the phono output on the Musical Fidelity M6si sounds if it is available after Feb 22nd like I've read.
