DH Labs Silver Sonic USB Cables
audioluvr
Has anyone tried these? I just ordered their HP cables in 3m length because they had a black friday sale and I've been wanting to see if there is a difference between digital cables (I was skeptical). First impression was they seemed quieter than the $19.99 Staples printer cable I've been using. By the 4th song in my reference collection I had this sickening feeling that something was terribly wrong. EGADS! They were sucking the life out of my music! I put in my cheapie printer cable (was actually an expensive cable for printers if there is such a thing
) and the music came back to life! Soundstage came back to it's awesome glory and vocals moved forward about 3 feet. Should I send these back as defective?
Maybe you're more of an inkjet printer vs a laser printer type of guy.
You may be onto something there!
Obligatory "it needs to break-in" comment!
Doesn't really help you and not really related to your original post, but I ordered a few of these a while back and thought they sounded good for the price: https://www.ebay.com/itm/265155084250
So I, out of sheer luck, was looking for other cables when I remembered another thread about Revelation Audio Labs cables being crazy good and came across this.
http://www.revelationaudiolabs.com/cables-digital/#USB
Regarding their Prophecy CryoSilver Reference DualConduit USB 2.0 Digital Link cable which separates the power portion of the USB to eliminate unwanted noise and distortion. So I started doing some sleuthing on who else does this and what, if possible, this does to the sound. Apparently this makes a HUGE difference. So, WTH, I'm testing my cables and my printer cable that I'm using has NO 5v continuity on it's pin! @Clipdat, you are a genius! Some printers do not need the 5v hand shake as they are internally powered. They only need the ground for clocking (or something) whatever that means.
Also found a cheap way of testing if your DAC is internally powered.
Interesting. Right now I'm using the Audience Au24 SE+ USB cable which has a separate physical wire for power which then re-joins at the connector. The concept is the same though, getting the power physically distanced from the data.
There are several maker of cable doing that now. I first seen it with a Pangea cable. -
@daniel0440 reported
