Do I need to have a receiver?
Leonhard1
Do I need to have a receiver?I just purchased a poke X T Center speaker as well as tower speakers. Do I need to have a receiver in order to hook this up to my television?
Yes, those are not powered speakers. You will need a receiver, speaker wire, and cables to connect the tv and any other components to the receiver. Unfortunately, receivers are hard to find these days apparently. I would look at used ones on ebay or local.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Second guy this week that thinks he owns poke speakers. It's POLK.
Plok Audio
dust covers pushed in from the factory maybe???
So if I’ve ordered a POLK sound bar, am I gona need anything else to use with say my tv or even just listening to music via Bluetooth ? I’m new here.
Also, how long is the shipping wait approx?
Most of our Polk Soundbars will come with your basic wiring to get you started. Which model did you order?
