Polk S15 mounting
Guys - is there any slim bracket I could use to mount the S15 speakers directly onto the call? I don't want to use a shelf as it'll protrude out too much. I do have beams I can screw into
can anybody help with this? Thanks
The Internet is full of wall mounts for speakers. Here's one, https://www.rockvilleaudio.com/rhsb8-for-polk-audio-s15/Political Correctness'.........defined
President of Club Polk -
Maybe a dollar short and a day late on this but: I went with the s10 instead partly because I could use a lower profile screw mountFamily Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
Basement 5.1.2: CS400i, RT55i, RT25, PSW450, MC60
Living Room Stereo: SDA 2a -
I'm looking for some sort of low profile bracket vs a wall mount/stand
They have built in keyhole mounts. Not sure how much lower profile you can go... -
I see only a single keyhole mount. Or am I supposed to remove the 4 silver screws and use those to mount?
That mount I provided a link for allows you to butt the speaker pretty much against the wall. What else do want!?!Political Correctness'.........defined
