Lsi25 Build
VR3
Hard to believe this is the first lsi25 I have done! As well as a lsic!
Clarity cap csa
Jantzen mox resistors
Mundorf electrolytic bypass by clarity sa
Jantzen and ersa inductor
Point to point
Delrin substrates
Clarity cap csa
Point to point
Delrin substrates
I bet you'd never get those through airport security. Beautiful job!
Nice and crafty....as usual. Do they need new cabinet mounting locations or drop right in?Don't take experimental gene therapies from known eugenicists.
Thank you! They should drop in the top of the enclosure like the stock ones. That's why I made it three pieces to give it some flex- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
SeleniumFalcon wrote: ยปI bet you'd never get those through airport security. Beautiful job!
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Really nice! I've always liked the design/looks of the LSi25.
What is the last photo, the terminal plate? Signal goes through that first before going to the main crossover? -
The last photo is the lsic crossover. The lsi25 is integrated into the plate Amp faceplate. To you fancy cable users, that means you are getting 4 or 5 ft of generic ofc copper between the terminal plate and crossover ๐๐๐
Got it, thanks for the clarification. Nice tidy build as usual, I'm sure the audible improvements will be obvious.
Sid shipped me a set of LSi9 crossovers he redid for me in cigar boxes at least 10 years ago (pretty sure they were the first LSi crossovers he ever did)......he showed me pictures and I was like "there is no way these arent going to be flagged.....lol The pictures are on this forum somewhere, they look like wires and sticks of dynamite...lolLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Had to access the old External hard drive to find those pics!
Have come a long way since then but they sounded excellent!
Your kraft has improved tremendously!
maybe not as pretty but they get the job done...lolLiving Room 2 Channel -
