RDO -194 tweeters
There should be a red dot for positive- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No red dots. One silver connect one gold color connect
Gold should be positive if I recall- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Are these 194 or 198 ?
Should be 194- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
198 has two different sized connection tabs.
One tweeter 194 has lose connector and don't work. Is it a easy fix.
