Rear Center Speaker
MikeT66
MikeT66 Posts: 21
edited June 2004 in Speakers
Would like to know what you guys recommend for a rear center speaker? Have a receiver capable of 6.1. Only have left and right front, center, and left and right surround plus sub. Looking to get a center surround. My speaker types are posted below. I respect everyone in the forums opinion and want to get something good. Any help would be appreciated....THANKS
Mike T
Onkyo TX-SR501 (Receiver)
Polk R50 (Fronts)
Polk R20 (Rear Surround)
Polk CSi3 (Center)
KLH Sub
65in Mitsubishi HDTV
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2004
    How about another CSi3 for the rear?
  • scottvamp
    scottvamp Posts: 3,277
    edited June 2004
    I would just get another CSi3 - that would be the way to go!!!!
  • TheReaper
    TheReaper Posts: 636
    edited June 2004
    Not knowing what to get myself, I experimented swapping speakers around. I found that either the same speaker as the surrounds, or one step larger worked best in my room/settup.
    That would be either an R20 or R30 in your case.
    Toshiba 42" RPHDTV
    Toshiba DVD
    Onkyo 360w 6.1
    Polk R50 L/R Mains
    Polk R30 L/R Surrounds
    Polk R20 (2) Center
    Polk R50 Rear Center
    Polk R15 L/R B-Mains
    Yamaha Left Sub-Woofer
    Yamaha Right Sub-Woofer
    Sony Main Sub-Woofer
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • fgr41
    fgr41 Posts: 432
    edited June 2004
    Im going to follow the popular opinions and go with either the CSi3 or the R20. Keep the rearcenter matched to blend it in.
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
  • mwhip
    mwhip Posts: 31
    edited June 2004
    I use a csi20 as my rear. It works great since you are only getting ambient noise out of it. The thing sucked for dialogue when I had it as my main center.
    7.1!!!
    2 R30's
    4 RT15i's
    CS245i
    Aiwa Sub
    Pioneer VSX-D912k
    Philips HDTV - 50PP9202
