New to streaming
My Wife got me a fire tablet thingey.
I've always been a tape, vinyl and cd guy but I must say I am digging the whole
streaming thing. Lots of choices.
I found a station called 61 Blues listen live out of Chicago, been running for a few hours along with my foot groovin.
In the past I visited few fellow polkies and they had these streaming setups with like a few million songs it seemed. Now I know why they do it. Never thought I'd say that.
This is cool!!
I did order a longer 3.5mm to RCA cable so I can tinker with the tablet while
sitting in my chair.
So, FWIW I'm sure I will be having some questions on how to enhance this capability.
  • skrol
    skrol Posts: 3,464
    Streaming music does have it place in the world. It is great for discovering new music that you may not have even thought of.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • oldrocker
    oldrocker Posts: 2,590
    Ok, tired of using the 3.5 to rca cable.
    Need some help :(
    I need "something" that plugs into my amp via rca inputs that will pick up the BT signal.
    I did buy one device thingey, cept I have to power it with the tablet charger to make it power on.
    Nothing fancy, just some sort of simple BT box thing, rca cables to the amp and its own power cord that plugs into the wall.
    David
    audioluvr Posts: 5,989
    You can go cheap with a bluDento run via Bluetooth from your phone or tablet. Or expensive. What do you want to spend? What level of reproduction do you want?
  • oldrocker
    For starters, just cheap and simple.
    Later, move up the ladder.
  • Or you could save that money (not much I know) and put it towards a Squeezebox Touch. I run Logitech Media Server on my desktop computer, which is on all day anyways. Qobuz works great. Tidal works great with the caveat that the hi res files only play their Redbook versions or they are downsampled....not sure what is the deal but I know the software developers working without pay haven't written an app to work with the MQA (for whatever reasons which they are silent on).
    If you got a subscription to something like Roon you wouldn't have any limitation with TIDAL. Qobuz is cheaper, unless maybe you go through Best Buy for your TIDAL subscription.
    I have heard that Bluetooth SQ isn't so hot.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • rooftop59
    rooftop59 Posts: 8,120
    yes, to second @Gardenstater, just buy one like this: https://www.ebay.com/itm/255384706879?hash=item3b761d5f3f:g:uLwAAOSwzpJiCTPF
    MUCH better sound quality, lots of apps and stations, control it from the tablet.
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59 wrote: »
    That's a good price, especially with COVIDnomics fully in effect. It may or may not have a remote but with a tablet I don't think you would miss it. I owe it to @rooftop59 @msg and @jdjohn for getting me into the SBT and I like it so much I bought a second one. Even lowered the noise floor in my system by getting me away from computer generated noise spill over into the digital USB. You may eventually want to get an external DAC but the internal one isn't shabby.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • oldrocker
    BluDento on its way.
    After a while, will get a DAC but that's many more questions for another day.
    Once again THANKS
    Good choice. I have a couple of the cheapie Chinese Bluetooth DAC's but the bluDento is by far the best sounding $100 ish or less one available. I use the Tidal app on my phone to run it through a cheapie/ freebie AVR in my barn and garage for commercial free tunes while I'm working in there.
    Later if you want critical listening via streaming you can wade through all the opinions here on what's best for you. :D
  • oldrocker
    I did start reading thru a bunch of those opinions for about only about 5 minutes :D , said the heck with that and threw out the question :#
    I did discover what DAC actually means
    David Ask Crazy. Crazy questions I tell you.
  • smglbrth
    smglbrth Posts: 1,499
    I just bought the Auris Blume Pro. Like you, wanted something to get my feet wet but nothing seriously expensive. I have this to say about it. It does sound pretty danged good, not near the quality of my CDP but good non the less. The RCA sounded better than the digital outputs. Of course, the digital outs were going to my integrated.
    I see this as a way to listen to new tunes, or a playlist while I'm cleaning the house and whatnot...
    pitdogg2 Posts: 27,335
    LMAO you nailed it!!
  • oldrocker
    Eventually I'll get somewhere up the ladder.
    Trying to get a starting point for my R200's in a different smaller setup.
  • oldrocker
    Not helping with the confidence their Boss.... :D
  • oldrocker
    And on another note, since it's my thread.
    I made blueberry muffins with yogurt instead of milk, wife said I was nuts.
    They turned out PERFECT. HA!!!!!
