Helpful tips
subman32
Ok i've heard of many tips out there. And I find the BEST one ever was using a AA battery to determine positive and negative when wiring your speakers/subs. I learned this simply from reading forums and I was wondering if any of you guys use this battery-helper? and whats your best shortcut in wiring or installing???
-Garry
We all learn new things everyday
-Garry
Post edited by subman32 on
I buy speaker wire with a stripe on one lead. I use bare wire connections, and always connect the stripe to the "-" terminal. No testing needed.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
