Safely moving SDA's
It looks like a long-distance move may be in my future and I'm looking for advice on the best way to pack a pair of 2.3TL's and move them along with other belongings. I plan to JB weld the magnets and understand the need to have them on their backs when transporting. What other protection measures should I take and has anyone successfully found a way to box and/or bubble wrap them?
  • Emlyn
    Emlyn Posts: 4,868
    edited August 2021
    I moved a few pairs of SDAs simply by standing them up straight up and strapping them to the side walls of a U-Haul truck so they wouldn't move and then leaned a mattress on them so nothing would fly into them when I was taking corners too quickly. No damages incurred. Also moved some by laying them down flat on a couple blankets in the back of an SUV. I had one pair shipped to me through freighters and craters standing upright on a pallet.
    Making a plywood crate lined with insulation foam board seems to be one reliable way to go. Only need a portable circular saw and the materials to do that.
    F1nut Posts: 52,156
    ^ This ^
    nooshinjohn Posts: 26,064
    Where are you moving to?
  • Schurkey
    Schurkey Posts: 2,122
    Put a jumper wire between the + and - binding posts of each speaker during transport. Reduces speaker driver motion. Keeps the drivers from flopping on their suspension.
    Toolfan66 Posts: 18,291
    Schurkey wrote: »
    This is the first of me hearing this little trick..
  • Schurkey
    When I U-Hauled my SDA SRS 2s 1800 miles, I pulled the drivers out so they could ride comfortably in the car. But when that's not practical, a jumper wire as described works wonders.
    It's been posted on this forum before--which is probably where I learned about it.
