Regarding connection without AVR
Hi,
I've purchased Polk T15, T30 ,T50 along with PSW10.
Ive below questions
1. Can i connect subwoofer without AVR ?
2. If i connect DTH audio out to sub woofer Line in using RCA cable and T50 to speaker out of subwoofer , whether it will give desires output ?
3. If not what are other option to directly connect from other devices withoit AVR ?
Best Answer
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,366
    Answer ✓
    They are there to provide a convenient connection for owners who are using a speaker level input from their receiver instead of a line level connection. Speaker level from their receiver to subwoofer, speaker out connections to speakers.
Answers
  • SeleniumFalcon
    Hello,
    Welcome to Polk's forum. The amplifier that is built into the subwoofer will only power the subwoofer not any external speakers. You will need some kind of external amplifier to power the speakers.
  • piyushsprem
    then why speaker out terminals are there in woofer
  • CFarrell_SoundUnited
    Speaker terminals are provided for hook up flexibility. Example: Some passive subwoofers also provide high pass filters allowing connection from AV receiver to subwoofer, subwoofer to small satellite speakers.
