Just purchased Oppo 103D and need a remote?
Any help would be greatly appreciated. Picked this up for a song and dance and did not come with a remote. Watched a movie last night and everything seems to work good. Thanks. D
  • muncybob
    muncybob Posts: 3,266
    I use a Harmony 650 programable remote for my Oppos, works fine for me. The Oppo remotes command higher pricing. The Harmony will set up all devices to watch a movie with 1 button.
    Yep, my name really is Bob.
  • PSOVLSK
    PSOVLSK Posts: 5,400
    My Oppo remote bit the dust and I use a Harmony One. The Oppo replacements are expensive…at least they were the last time I checked into it.
  • Emlyn
    Emlyn Posts: 4,824
    If it's networked, the 103D can be managed from the app that Oppo developed. It'll also be mostly operable with any Oppo remote going back to the 83 model. Here's some info:
    https://www.oppodigital.com/support/blu-ray-bdp-103/blu-ray-BDP-103-Support.aspx?prodID=BDP103D
    Since it's a 103 "D" for Darbee the only remotes that will have the Darbee control function button will be the 103D or 105D remotes. Not sure if the Darbee functions are available from the regular Settings menu without that button or not.
    pitdogg2 Posts: 27,303
    edited August 2021
    Yep there's an app for the Oppo 1xx players in the app store. I downloaded the app for my 205 it works pretty good.
  • PSOVLSK
    Good call. I actually have this app on my phone, but never use it since I use the Oppo. It did work well when I used it though. I might actually use it more, but 1) I seldom use my Oppo and 2) like now, I forget I have it on my phone.
  • Dabutcher
    Dabutcher Posts: 2,606
    Thank you gentlemen. I will download a couple of the remotes to my iPad Pro and try them out.
    Love yours. D
