Are these "OLD" and worn out Solen Capacitors in my Hartley's ?
Tony M
Tony M Posts: 11,853
edited August 2021 in Technical/Setup
What do you think about these Hartley Solen Capacitors ( red ended ) that I think are heating up and causing distortion. Do I need to have a diagnostic machine to test their specs to tell? Or do the red ends mean= OLD. I thought there was a little resistor behind the Caps for some reason. :s
Newer Solens have white ends. Should I go ahead and order the white ended Solens?
newer ones;
    mhardy6647 Posts: 35,354
    They do appear to be old Solens.
    They should be fine -- well, as good as Solens get :)
    I mean, you can check them for ESR in circuit and/or capacitance out of circuit, with an ESR meter or an LCR meter, respectively.
    Cheaper to replace. Solens are cheap capacitors (in both senses of the word).
    VR3 Posts: 29,625
    They are probably as good as the day they were installed.
    Your issue of distortion after listening for a bit would be a voice coil I would guess
    Thanks guys.
    I'll concentrate on the voice coils and tube alignment now.
    They do have a minimal air gap between the tube and center pole.
    Thanks again.
