LSi9 and Parasound HCA800II
radkrisdoc
Hi guys...Ive been lookin for a nice inexpensive amp, and Ive come across the Parasound HCA80II quite often.....can you all tell me if it would be a good choice for the LSi9's? Here's the specs for this amp:
HCA-800II Specifications
Continuous Power Output - Stereo
100 watts RMS x 2, 20Hz-20kHz, 8W
150 watts RMS x 2, 20Hz-20kHz, 4W
Continuous Power Output - Mono
260 watts RMS, 20Hz-20kHz, 8W
Current Capacity
28.3 amperes continuous
40 amperes peak, up to 200msec.
Slew Rate
60V/m second
Frequency Response
8Hz-90kHz, +0/-3dB
Total Harmonic Distortion
< 0.08% at full power
< 0.03% typical levels
IM Distortion
> 0.1%
TIM
Unmeasureable
Dynamic Headroom
>1.5dB
lnput lmpedance
30kW
S/N Ratio
>104dB, input shorted, IHF A weighted
Damping Factor
Over 100 at 20Hz
Dimensions
17 1/4" wide x 3 3/4" high x 11 3/4" deep
19" wide using RMK-800 rack mount kit
Weight
23 lbs.
Special Features
700VA toroid power tmnsformer
60MHz output transistors, in A/AB mode
30,000ufd gold capacitors in power supply
Cascode Class A input stage
Gold-plated input jacks
The things that look different are slew rate ( a low 60), a damping factor of 100 ("over 100") and an IM distortion of > yes > 0.1%. I know that listening is believing, but I have no way of checkin these out. Gotta have some opinions though, maybe some of you might have experience with this amp. Thanks in advance for the advice! Kris
Current Capacity
Slew Rate
60V/m second
Frequency Response
8Hz-90kHz, +0/-3dB
IM Distortion
> 0.1%
TIM
Unmeasureable
Dynamic Headroom
>1.5dB
lnput lmpedance
30kW
S/N Ratio
Damping Factor
Over 100 at 20Hz
Dimensions
Weight
23 lbs.
Special Features
