I'm looking for a center channel for older bookshelf
I have a pair of RTi4 and I would like to know if the CS1 Monitor Series II center channel would be timbre matched for them.
Also, my setup have room for a 18" width center channel, does the CS1 are a tad less than 18" ?
Surround are the RM6700 kit.
Answers
It’ll work but it’s not a match. The correct center is a CSi3, easily found on eBay. Since I always recommend going with the biggest center you can fit/afford, I would also look for a CSi5. The newer csiA4 and csiA6 would also work…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
