Polkaudio RTA 8T
DomC1956
Hi, I'm new to this group but I have a pair of RTA 8T's that I purchased in the very early 90's, I just picked up a Scott 299C amp to use with my RTA 8T's and noticed the SL 2500 tweeter wasn't working on one of the speakers. I took it out and hooked up another tweeter just to test that it was the tweeter and it works fine. Where is the best place to purchase a replacement tweeter? And should I upgrade the tweeter to the SL 3000 or use another SL 2500?
Thank you
Dom
Thank you
Dom
Hi Dom,
Welcome to Polk's forum. Polk made a replacement for the SL2500 called the RD0198-1 and it was very well received. I may be wrong but I don't believe Polk has any of them remaining, but you can check with them at 1-800-377-7655 and follow prompts for parts. If they don't, I see there are some for sale on eBay that seem reasonably priced. If it were me I would replace both of the tweeters it would clearly be audible over the originals.
Cheers! -
Midwest speaker had them.
yes buy two they are worth the money..
https://www.midwestspeakerrepair.com/shop/home-audio/tweeters/polk-audio-1-tweeters/polk-audio-sl2500-sl3000-1-inch-dome-tweeter/ -
Do you have 8T or 8TL? 8T's had the SL2000 tweeters. The correct replacement for those are the RD0194
Hi and thanks for the reply's. I'll give polk a call, I'll also check out eBay and midwest. The label on the back of the cabinet says RTA 8T 31692.
Show a picture of the tweeter we can help you get the correct one.
Here you go
RD0198 is your huckleberry
Just ordered two RDO198-1 from Polk Audio, Thanks everyone for all the help.
