Not sure which SDA 2 these are.
johnkalio
johnkalio Posts: 14
edited May 2021 in Vintage Speakers
Hello all,
I've been looking for a pair of Polk SDAs any model I could find but not much these days here in Canada. I stumbled on these SDA 2s. I can't tell which ones they are. I attached the pics for more clarity. I know that the tweeter on one has been changed they are pin/blade and no interconnect cable from what the owner's daughter has told me. Not sure if the are desirable either compared to the other models.
  • DaveHo
    DaveHo Posts: 3,584
    First pic is not the same pair of speakers. Those are 2B's. I believe because of the blade/blade interconnect, the others are 2A.
  • Unknown
  • johnkalio
    johnkalio Posts: 14
    DaveHo wrote: »
    These people are fools. No clue what she has now. Thanks for the reply.
  • johnkalio
    johnkalio Posts: 14
    DaveHo wrote: »
    Unreal. lol
  • johnkalio
    johnkalio Posts: 14
    DaveHo wrote: »
    First picture is a mistake sent by her. I will remove it.
  • johnkalio
    johnkalio Posts: 14
    SDA2a but the very first picture is of the SDA2b two very different speakers
    First pic is not correct, removed.
  • Gardenstater
    Gardenstater Posts: 4,985
    Maybe they work for NASA and they used the same procedure they did on the moon photos lol.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Unknown
  • johnkalio
    johnkalio Posts: 14
    SDA2a. You'll need a good amp to drive them properly. They start at 4ohm and drop to low 3ohm, many receivers will or can go into protection mode driving them. I would NOT use that interconnect cable without the proper spades or switch the connection on the speaker to neutrik connection.
    https://www.neutrik.com/en/product/nl2fx
    I have not bought them yet. Doing my homework before I watse my time and money. Do you think they're woth it? If I do get them I have a few Yamaha M80s I'm sure could rock these speakers.
  • Unknown
    edited May 2021
  • johnkalio
    johnkalio Posts: 14
    johnkalio wrote: »
    Hello all,
    OK please be very clear as to what you are asking
    The bold above Pin/Blade model will be a SDA2b very desirable speaker easier to drive at 6ohm.
    If they are Blade/blade then those are SDA2a a less desirable and a very demanding speaker as to needing a dedicated amp. The Yamaha M80's were decent amps but very long in the tooth and in need of new caps and possibly other parts on the boards.
    The pics I posted above are for a pair that I'm looking to buy. I'm not sure if they are 2As or 2Bs. It looks to me pin/blade from the pics, I think. Also would they be desirable as you mentioned if they are indeed 2Bs.
    F1nut Posts: 52,406
    They are way beyond a shadow of doubt the 2A with the blade/blade SDA cable connections.
  • Unknown
    edited May 2021
  • johnkalio
    johnkalio Posts: 14
    Thanks for the reply. New to the SDA line.
  • johnkalio
    johnkalio Posts: 14
    johnkalio wrote: »
    The picture you included of the interconnect socket is of the SDA2a. It is a Blade/blade socket. They are good speakers but need a good amp to function properly long term. Like I said the SDA2a are a 4ohm speaker that drops to the low 3ohm area.
    The SDA2b (not pictured) ARE pin/blade. They are 6ohm and are a much better speaker than the SDA2a. (but look very similar in that both have 2 drivers and a tweeter and 12" passive radiator)
    The Pin/blade speakers had the socket inside the binding post cup instead of outside the cup like earlier models that had the Blade/blade connection.
    Thanks for the clarification. My head is in the clouds today. The SDA 2a which I posted are the harder to drive ones. The 2b are easier to drive.
  • Unknown
    edited May 2021
  • johnkalio
    johnkalio Posts: 14
    correct.
    I've had the SDA2a speaker. I even recapped the entire crossover. It is a more expensive endeavor due to the cap sizes used in the SDA2a crossover. BUT it can be a very nice set of speakers. What is the price they are asking?
    They are asking $300 Can. But wrong tweeter and no interconnect cable. I should offer her $100.
    F1nut Posts: 52,406
    edited May 2021
    johnkalio wrote: »
    The M80 is a dual mono amp meaning it is not a common ground amp and therefore cannot be used with the SDA 2A.
  • invalid
    invalid Posts: 1,560
    I've blown up plenty of amps and receivers over the last 30 years with my sda2a's. They are really nice sounding speakers especially if updated with new rd0194 tweeters and new caps, but they are hard to drive
  • johnkalio
    johnkalio Posts: 14
    johnkalio wrote: »
    You learn something everyday. Sheesh. Now i'm really out of luck. lol
    F1nut Posts: 52,406
    johnkalio wrote: »
    johnkalio wrote: »
    The later models with the pin/blade SDA connection can use non-common ground amps with the use of an isolation transformer.
  • johnkalio
    johnkalio Posts: 14
    johnkalio wrote: »
    johnkalio wrote: »
    Would I be able to drive any of the smaller SDAs?
  • johnkalio
    johnkalio Posts: 14
    johnkalio wrote: »
    I haven't checked it myself yet, but they say the M80/M85 are common ground amps.
    F1nut Posts: 52,406
    edited May 2021
    Who says?
    Something I just found....
    The Yamaha has a good power supply ( TRUE dual mono with individual iron core non-toroidal transformers for each channel ).
    True dual mono does not share a common ground.
  • johnkalio
    johnkalio Posts: 14
    Who says?
    "The easiest way to see if an amplifier is common-ground and therefore suitable for SDA speakers, is to plug an ohmmeter across the two channel's negative terminals, to measure the resistance" That's how I will check it later on this evening to be sure.
    F1nut Posts: 52,406
    Yep, better do that.
