Onkyo a-8190
I Bought a Onkyo a 8190 3 months ago. It had a lot of static in it when I turned the knobs and the left channel would go on and off so I opened it up and it was the dirtiest amp I ever seen so I cleaned it with a spray cleaner and took off the front cover and spray the controls with a contact cleaner I did all the 3 times put it back together hooked it to my infinity RS 4bs and it didn't sound that good. So I put my Yamaha a 500u back anyway about 2 months later I hooked back the Onkyo and it sounded pretty good so I cleaned it again and it even sounded better now I don't which one to keep which one is the better amp
    pitdogg2 Posts: 27,918
    The one you like!!
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Keep them both.
    mhardy6647 Posts: 35,562
    Keep them both.
    ... and pick up a couple more while you're at it. :#
