Polk RT7 ports
can anyone tell me what the port dimensions are for the RT7 bookshelf?
thanks
thanks
I have an old pair of cabinets, what dimensions specifically do you need for the ports?
i need the diameter and the length of the ports. i have the drivers and crossover. i want to build new cabinets for them.
thanks. -
I’ll get the measurements soon
thanks much. greatly appreciated!
So, the two ports are different lengths.
And the outside of the port is fluted as shown in the bottom of this photo
The longer port tube measures 7 3/4 inches to flush with front
The shorter tube located on left side is 4 1/4 inches from back of cardboard tube to flush with front. Both measurements I provided are approximate.
The tubes are approximately 1 3/4” I.D. Pretty hard to measure precisely
The cardboard tubes appear to be inserted into the fluted plastic front piece and hot glued together
thanks so much dromunds for providing these measurements and pictures. this was the last thing i needed for my new project.
-Mike
