6sn7
daboyz
Looking for a quad. Looking to spend approximately $100. Could go more for the right set. If you have them or can recommend that'd be awesome.
https://www.ebay.com/itm/174768008318?hash=item28b0fc2c7e:g:STcAAOSwm2JgPBcE
https://www.ebay.com/itm/324618860074?hash=item4b94cab62a:g:QvMAAOSwXLFgiO~E
https://www.ebay.com/itm/333505367626?hash=item4da6780e4a:g:8lQAAOSwUvheOg-Y
Bought from this seller before
Vvvvvvvvvvvvvvvvvvvvvvvvvvv
https://www.ebay.com/itm/133456447512?hash=item1f129fc818:g:23kAAOSwLahay6h6 -
Dave - all four sets look ok and once they arrive we can run them through the tester to verify. Just insure there is an easy return policy.
I’d be biased towards the 4th set.
Sylvania’s will be a bit brighter than the Ratheons. I’ve had less microphonics with the flat plates in what I’ve got here.
If you’re going to bite on one of these sets let me know which one as I might jump on one of them.Aaron
Enabler Extraordinaire -
What piece are they going into?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Unless he’s hiding more gear these are for a Rogue 99 preAaron
Well if that's the case then he won't need those top of the line tubes. He can use these.
https://www.ebay.com/itm/223584308733?_trkparms=ispr=1&hash=item340ea9cdfd:g:VJoAAOSwUfNXRvXy&amdata= -
A2 is correct on the pre. I'll text ya on which set I'm looking at.
Thank you, Ivan.
Lemme look, I have a pair....not sure I have 4 laying around. I'll check when I get home. Wanna say they are RCA's.
I'll check when I get home...I plan for the future. - F1Nut
