Upgrading tweeter in an RTi10
Would the ring tweets used in the LSMi or Reserve be able to just be "dropped" into the 10s, or would the cabinet need to be modified?
    pitdogg2 Posts: 27,376
    There are not drop in, they more than likely will need both cabinet and crossover mods to use them.
    F1nut Posts: 52,032
    juggbigt wrote: »
    NO
  • rooftop59
    rooftop59 Posts: 8,120
    juggbigt wrote: »
    Sell the RTis and get something less bright...
    Game Room 5.1.4:
    Bedroom 2.1
  • gp4jesus
    gp4jesus Posts: 2,019
    Very difficult to remove existing tweeter from the bezel w/out destroying it. Either:
    1. Upgrade the speakers’ passive XO components as a few have on this forum or had another member (VR3) do it for them: F1nut, Booker, JC sound to name a few
    2. Yank out all the passive XO components and, except for a DC blocking cap, tri-amp ‘em - I did. Then you can use any tweeter you want. The EXO won’t care
    3. Learn to live them as they are
    My $0.02 cents
    *all connected w/Premiere ICs
