Sub speaker level connections
muncybob
I'm looking for a sub and need these connections. I've seen some subs with just the input connections and other with both the input connections and also output. Why would you use both?
Yep, my name really is Bob.
I think it's just to go back out to the speakers from the sub. Not 100% on whether the output signal will only be high-pass, though. That part may vary by manufacturer?I disabled signatures.
Yes some like the Martin Logan dynamo have a built in high pass at 70hz (a few have an adjustable high pass) when using either the speaker level or line level outputs. Allows you to take some strain off smaller bookies. Input on that one is variable crossover iirc...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Crossover slope is also something I've been curious about for blending, but I'm not sure I've seen that specced in any manuals I've read so far.
One of the things I read about in MartinLogan documentation was to set the sub's crossover at 70% of the speaker's low frequency output spec as a starting point. I've tried this and found it to be a good starting point for blending the sub.
Prior to reading this, I'd typically set the sub's crossover right at the speaker's low frequency output spec. Seems to depend on the sub, speakers, room, etc., but that 70% recommendation from ML must take into account the crossover slope? I would think that it is more gradual vs a steep drop-off? Anyone else have any experience here?I disabled signatures. -
The output can be used to daisy chain another sub
@muncybob
Here you are:
https://forum.polkaudio.com/discussion/193848/2-sunfire-hrs-12-subwoofers#latestPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Yea, I saw those. A bit far for me.Yep, my name really is Bob.
