RT600 vs. RT600i
jinguoyu
RT600 is discontinued. The new RT600i looks better. What is the difference in performance between RT600 and RT600i?
I don't quite know the difference between the two in sound quality but as far as I know, it is the material of the cones of the speakers that is different. Please correct me if I'm wrong. Regardless I purchased the RT600i's a while ago and I still am impressed with them, at first I jacked it with as much bass as possible and it pumps out quite a bit. But it lacks a bit of mid-range, so I bought a PSW-350 sub to take off the bass load off the 600i's and it sounds it bit better. If you're thinking of buying these give the 800i's a try they sound a bit better and have good mid-range.
Just my opinion:) L8r
