HELP ! ! !.....Need to know if a special tool is needed to replace tweeters on Monitor 60
Is there a special tool needed to replace tweeters on Monitor 60 II speakers... Are there videos available ? ? ?
  • guyincognito
    I don't have experience with this exact speaker but I've fried a couple tweeters so I feel your pain. From photos all the drivers seem to be held in by Allen head screws and shouldn't be hard to remove. When I replaced the tweeters in my Revel F208s and my previous HTD tower 3s (like I said I have made some mistakes) the tweeters where stuck in place after removing the screws. I'm not sure if its glue overspray or tacky finish when the drivers where installed at the factory but you will probably have to pry them out carefully without damaging them. I have a small hook and pick set I inserted into the screw holes to pull mine out. After they pull free it was just a matter of swapping wires (solder or spades in my experience). Hope this helps as im not sure what problem exactly you are running into.
    Kyle
    Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
    Aurender n100h, Benchmark DAC2 HGC
    Arcam SR250, Parasound JC5
    Revel F208, SVS SB-4000
  • guyincognito
    Just curious if you have resolved your problem? Hope you are back in listening bliss.
