Polk lsim705
Will the Marantz PM 7000N Integrated Amplifier be good with Polk lsim 705?
Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren
  • Milito
    Milito Posts: 2,002
    edited February 2021
    I have 705's, and you would need more power than that for them to sound good. My Music Hall A70.2 integrated amp has 125 per channel, I also ran them with a B&K 4420 with 225 per channel.
    Sixty watts per channel won't sound very good with them.
    Clipdat Posts: 13,078
    Warren, which amplifier are you currently using with them?
  • warren
    warren Posts: 756
    Clipdat wrote: »
    Pre Yahama 3010, Rotel 991 Amp
    Some final words,
    Warren
    If you are referring to this: https://www.crutchfield.com/S-5enVQvYZAic/p_022RXA3010/Yamaha-RX-A3010.html
    I believe you'd have better luck using a nicer/dedicated preamp (maybe tubed) in front of your Rotel. You might be surprised at how much using an AVR as a preamp can bottleneck your amplifier's performance.
  • warren
    warren Posts: 756
    Clipdat, thanks! I have been thinking along that line. Any suggestions, with pre outs
    Some final words,
    Warren
