12 in Speaker stands
Easy Runnin
in Speakers
I'm looking for a decent pair of 12 inch tall speaker stands for a pair of RT55s.
Any suggestions?
Any suggestions?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
That seems short?? I think I had mine on 24” stands.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I agree. They are currently on 16s. But with french doors, a fireplace and a wet bar taking up 3 of the 4 walls in the room, I’m forced to put the TV in a corner. The new TV is larger and now depending on your seat, the speakers block the lower corners of the screen. Lowering them 4 inches should correct that issue. And as a bonus, the next TV could even be larger.
The problem is finding stands that short.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
BR - Yamaha CR800/Polk monitor 5 -
Milk crate
Maybe this ones.
https://www.americanrecorder.com/products/high-performance-speaker-monitor-stands
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
May want to look into studio monitor stands instead of home theater oriented stands so the speakers can have some upward tilt applied to them. Here's an example:
https://www.amazon.com/dp/B078YN86Q5/ref=sspa_dk_detail_4?psc=1&pd_rd_i=B078YN86Q5&pd_rd_w=2BTfM&pf_rd_p=4269e1a0-a218-4fbd-9748-1cd337d2f2a5&pd_rd_wg=oqBDF&pf_rd_r=ZCTZ3S82DYBTN4HA1N7E&pd_rd_r=ff0926a5-f27a-423a-abd7-8f381cc205bc&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFWMk1PWDZFRTNKSEQmZW5jcnlwdGVkSWQ9QTAzOTgxMjAzTzk0VzZSRTdNSDIyJmVuY3J5cHRlZEFkSWQ9QTA2NDQyMjAzREtDTTEzOEU4MjM3JndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
