Csia 6 center channel speaker has white mold coat
After two months the bottom speaker has a white coating on it. I am assuming that it is mold. The top 6.25 inch midrange speaker cone is perfectly clean. Only the bottom 6.25 inch woofer has the white mold coating on it. Don't remember seeing that before when I brought the speaker home. If it doesn't affect the sound quality and doesn't get worse do you suggest to ignore the mold ?
Answers
    VR3 Posts: 29,631
    Have you opened the speaker to make sure there is no mold on the inside?
  • afterburnt
    afterburnt Posts: 7,892
    edited February 2021
    Top and bottom 6.25"? Do you have it sitting on end?
    F1nut Posts: 52,164
    Might have something to do with Thailand's heat and humidity, but I'm only guessing. Center channels should be horizontal.
