Anyone have experience with Sunfire True Sub EQ models?
msg
msg Posts: 10,452
Looking for information on the Sunfire True Subwoofer EQ models.
Wondering whether the EQ functionality is significant over the standard True Subwoofer models.
  • daddyjt
    daddyjt Posts: 3,074
    edited January 2021
    Amplifier power and driver design are similar. However, the “EQ” models have an automatic eq feature with a supplied microphone. The EQ is a powerful tool, and does a lot to smooth out room response. The manual mode is painstaking and difficult however but ultimately provides better room integration. However, it’s not nearly as useful as Velodyne’s - Velodyne incorporates on-screen display and almost infinite user adjustability via remote control.
    Normal Sunfire amp plate:
    EQ models back plate:
    ― Aleksandr Solzhenitsyn
    msg Posts: 10,452
    edited January 2021
    Haha, sorry, I should have been clearer. I meant to say - does anyone here have any experience with the True Sub EQ version.
    I hadn't looked at the manual, but was curious as to whether the EQ version was any good. I have a True Sub Super Junior and I like it, but it's a little small for the space I'm using it in. What I like about the Sunfire subs is that they offer bass timbre.
    I was considering checking out the 10 EQ, as there was one listed on the Bay in great condition with oe box and packing, but it went for more than I wanted to be in for.
  • daddyjt
    edited January 2021
    I’ve never owned one, but I did help a buddy set one up some time ago. You’d be better off IMHO picking up an outboard parametric eq - you’ll have FAR greater flexibility, and probably save quite a bit of money. The eq in the Sunfire is only a 4 band graphic...:-(
    msg Posts: 10,452
    Ah, okay, good info, thank you. This is what I was looking for.
