How to fix magnet slip?
Hi guys,
Is there a way to fix sliipage of the mangnets for the SDA drivers?sk2e7petfxgi.jpg
Answers
  • Gardenstater
    Gardenstater Posts: 4,837
    Assuming you mean fix ones that have already shifted, it can be done. As long as the voice coils aren't damaged and the DCR is in spec (measure resistance with a meter) you can use a simple fixture and fix it yourself, or enlist the help of others.
    Do some searching here and you'll find lots of info.
    lawdogg, xschop and others have posted information.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Would mis-aligned magnets cause a light scratchy noise? The noise only occurs at top and bottom of stroke.
  • Gardenstater
    edited January 2021
    Yep. Scratchy noise it is. Welcome to the nightmare :)
    It is actually usually the pole piece that is touching the voice coil.
    Another thing that can happen is you can have a damaged spider and that can sometimes be hard to detect by eye but usually it is a crack near where it joins the cone. People have repaired them with Ayleens Tacky Glue. I don't know how successful that is long term.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
