Which Speaker, RTI-A5 or S55?
I just purchased a set of RTI-A5's and S55's for my front speakers. I am looking for the best sounding as I am upgrading from RTI-A3's. The rest of my equipment consists of a CSI-A4 center, 2 PSW111 subs, and a Denon AVR-X4500H. I am at about 75% movies/television and 25% music.
I have both sets of speakers taking up room in their respective boxes to the displeasure of my spouse. Any assistance is appreciated.
    gudnoyez Posts: 8,159
    Well since its 75% Movies those RTIA5's will complement that CSIA4 center channel for a seamless front.
  • angelsfanatic
    angelsfanatic Posts: 5
    edited January 2021
    Thank you for your comment/suggestion. That was another one of my concerns, matching it to the center speaker. I know the RTI series and CSI are voice matched.
    How is the RTI-A5 with music? Will I be disappointed? The RTI-A3'S I have sounded okay with streaming music, mp3's, and CD's. I just seem to be missing something while playing vinyl and I don't quite know what it is. Maybe I need an analog stereo receiver to really get the most from my vinyl?
    I have RTIA9's a CSIA6 Center dual PSW 111s up front A5's and A3's as sides and rears, and couldn't be happier with them for HT. For Music I prefer to listen to a 2 channel system over the HT rig as the RTIA's are best being used in a HT set up, they do however do a pretty good job with concert Blu Rays in surround.
  • Nice. I am thinking about using the A3's as my rears now since I am only in a 3.1 setup right now. The wife probably won't want the speakers sitting behind the couch so maybe I'll just use them as front height speakers. Eventually I will put speakers in the ceiling for the surrounds.
    Thank you for your input and assistance. I might keep both sets and use the S55 speakers for music in my den.
  • JayDog
    JayDog Posts: 266
    Excellent Answer! Spoken like a true audiophile.. :D
  • Thanks JayDog. My only problem now is getting my wife's okay. She wants me to take one of sets back. I currently have an old set of KLH speakers in the den.
    They are hooked up to a JVC RX-709V that is still going strong.
  • Thank for all of the assistance. I got the A5's set up and they sound good. They are a little bright with some music, but I hope they just need to be broken in.
    I ended up setting the crossover at 60hz and small. I may end up going back to 80hz only because the subs are not doing much except for the very lowest of frequencies.
  • rooftop59
    rooftop59 Posts: 8,121
    The brightness won’t change much with break in. They are inherently bright speakers, designed for extra sparkle and shimmer on movie soundtracks...
    Game Room 5.1.4:
    Bedroom 2.1
  • You got em both, hook them up and give a listen. Let your ears do the deciding.
