NICE Luxman PD 272 direct drive manual turntable (Micro Seiki)
geppy1
Selling a nice Luxman PD 272 direct drive manual turntable. A classic with a great tonearm. This is for intents and purposes part Micro Seiki. The table works as it should and is nice shape. The wood is excellent as is the base .It is built like a tank. The mat is slightly browned from sun and the dust cover has some wear and one deep scratch on front Not a crack. You can get a new dust cover fro m the auction site. Comes with copy of the manual Overall very nice and sounds great Includes Audi Technica stand. I am asking $575 or BO for this which is in right in the middle of the going rate. Thanks
The Luxman PD272 is a two-speed, manual turntable using a DC servo motor direct-drive system.
Slots are completely removed to eliminate unevenness of rotation caused by electromagnetics, and further provided is a turntable platter of high inertia with which the large mass of the platter weight is distributed around the outer contour.
For the tonearm, a straight type is adopted to eliminate resonance caused by lack of solidity which tends to be found on the tonearm exclusively designed for high-compliance type cartridges.
Specifications
Driving method: direct-drive
Motor: DC servo brushless and slotless
Platter: 30cm aluminium die-cast 1.8kg
Speeds: 33.33 and 45rpm
Pitch control: +-4%
Signal to noise ratio: better than 60dB
Wow and flutter: no more than 0.03% WRMS
Tonearm: straight arm of static balance type
Effective length: 240mm
Overhang: 15mm
Cartridge weight: 4-11g
Stylus pressure: 0-3g (direct reading
Specifications
Pitch control: +-4%
Overhang: 15mm
