SDA CRS speaker questions!
sromeo55
Does anyone know the following about Polk SDA CRS speakers
1 - which of the tweeters - inside or outside is the directional tweeter?
2 - The wiring on one tweeter and speaker uses blue and white while the other set is black and white -
is the white always negative while the color is positive?
Thanks for your help!!
1. outside.
2. The schematic for the SDA CRS and SDA CRS+ states Blue/Black = Positive, Green/White = Negative.
1. outside.
- I dont think you are wrong - but i had someone comment on another forum saying the inside tweeter is directional. Just wondering where or how you find that out specifically. THANKS!! you rock -
The inside tweeter is in the Stereo Module; the outside tweeter is in the Dimensional Module. Not sure how you are using the term "directional"?
THANK YOU
