SUB security
aort237
what is the best way to keep your box from getting jacked. a lot of people at my school have had that happen to them and i dont want to be next.
Adam
Post edited by aort237 on
dont play your system loud in the parking lot, dont put stickers 'advertising' your equipment to thieves
and finally, get some carriage bolts and bolt it through the frame to the inside of the box, if they want to get the sub out, they have to take out each individual screw
Just Put a polk MOMO sticker on your car....nobody will steel it
joking
oh come on...It was funny -
no... no, it wasnt
besides, i'd rather get my car steeled than stolen... i mean, you can fix a few dents...It's not good, very fundamentally simply not good. - geolemon
another thought would be, if your using regular phillips screws, take a soidering iron, and soider, melt some into the top of the screw...Testing
Testing
Testing -
the problem there is that no one can get it back out... not even you (without drilling it out, of course
sure you can, melt the soider back down, in the screw of course, and there is a tool that sucks the soider back out, its mainly used for circuit boards, if your trying to disassembal it, melt the soider, and use the soider sucker.Testing
Testing
Testing -
for my sub box in my old car, I drilled a hole and bolted a loop bolt on the back of my sub box. I had originially planned to get one of those computer anti-theft lockdown kits and glue a piece on my amp, run the cable through some metal parts in the trunk, then put a lock at the end of the cable on the sub. I got lazy and never put the cable in.LSIm system on order =D
Currently listening to innovation...
Prior car systems:
Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500 -
hmm... didn't think of that... but what if the thief has a lighter? would that not create enough heat? and if they're in the car that far, perhaps they'd be willing to spend an extra minute to back out the screws?It's not good, very fundamentally simply not good. - geolemon
Lighter...I chuckled at that thought....some guy...in the middle of the night with his azz in the air sticking out of the trunk/hatch and using a zippo to try and melt the solder on who know's how many screws...lmafo! just look for the guy the next day with bandages on all his fingers
i just pictured that...
all you lacked was the sounds...
"oowww, damnit!, this **** burns, $*@# i burned myself again!"
To answer your question, no, a lighter probably wouldn't do the trick. Soldering irons get around 500 degrees. Yes, a lighter can too, but they wouldn't be able to get that heat directly on the solder to melt it. The box would probably start on fire first...http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
lol...i got so caught up in the thomas' story i didnt answer the question
hes right, if they had one of the windproof zippos it might do the trick, but im not sure how many thieves consider windproof zippos to be part of the 'tools of the trade'
even so...im not sure if they would spend the time to heat and unscrew every screw anyway...
